Originally Posted by
FilthyMonkeyRacing
Out of the 16 cars ive had never really had any "crappy cars" but my 1972 Chevelle broke down on a regular basis thanks to it being 30 yrs old at the time and a retarded 17 yr old(obviously me):punchout: that was driving it.
My 04 SRT-4 i also had a fair amount of problems.
1)When i first purchased it, it was only making 10psi instead of the 14 psi which i contributed more then likely to vacuum leak(s) or wastegate and it turned out to be several coroded vacuum lines that went to the factory "boost controller".
2)Then the first time it rained i had about two inches of water in the passenger side floor board which over the 11 months i had i slowly tracked down the leak to a combination of the sunroof and windshield and slowed the leak to where it only made the carpet on front passenger area damp.(water leaking was a common problem on the 99-05 neon chasis, stupid, cheap, profit hungry american car manufacturers)
3)Then timing belt broke at about 69,xxx miles(over $1200 to fix, thankfully had breakdown coverage on it that covered it all but $100 deductible)
4)....and the same day i got it out of the shop about 4 miles down the road the car when trying to go into 2nd gear when leaving a stop light it wanted to die each time i let off the clutch..turns out 4th gear welded itself to the mainshaft of the transmission w/o any discoloration or signs of overheating and that cost over $4k but all but a couple hundred was covered but warranty. All the rest of the time it ran like a raped ape! As far as performance it was the best FWD i ever had.
