For those of you who don't follow my turbo Lexus build thread on Club Roadster, here's the quick background.
I've had the car for several years as my daily driver. It's fantastic. Reliable, classy, comfy, sporty, etc. I recently brought it to Jeff Tsai of Power Dynamix for what he dubs the "Stage 2" turbo setup. Target power is around 375 at the wheels. Not difficult for a 2JZ.
I got the car back this week and soon discovered a **VERY STRANGE** bug. A full recounting is transcribed from CR.net below.
If anyone sees this and, in your vast history of car modification/maintenance knowledge, has insight into this really weird problem, please let me know.
This morning was STRANGE. I've experienced some automotive voodoo like none other. I've sworn, in the past, that certain cars were haunted or possessed. But that's always tongue in cheek. This time...notsomuch.
Last night when I picked my car up I turned the key to crank the engine and it didn't start. Jeff explained that, due to the oversized injectors, the car will occasionally flood and might need a little throttle to get it started. (Turns out this is almost never the case...but I digress.) He hopped in the car and it started immediately.
I drove it home, parked it and had a great night's sleep with dreams of open-dump wastegate (yes!) and fluttery BOV noises waiting for my morning drive to the office.
Got in the car this morning, turned the key and it cranked but wouldn't turn over. I gave it some throttle like Jeff showed me and it wouldn't turn over. Lexus has a "flood-clear" mode so I engaged that by holding the accelerator pedal to the floor and cranking for 10 seconds. Still wouldn't start after that.
So I called Jeff and he decided to come over during lunch to take a look.
He got to my house. Turned the key and the car immediately idled and purred like a very large, hungry kitten.
I told him that I was hoping that wouldn't happen but I was glad it did. Assuming it was just a fluke, he was getting ready to leave. Before he did, I wanted him to observe me starting the car just to make sure all was kosher. We shut the car off. I got in. Turned the key. Whirrrrrrrrrrrrrr. Wouldn't turn over.
Odd.
Jeff got in. Started right up.
I got in...wouldn't turn over.
FOR ONE SOLID HOUR the car started 100% of the time for him and 0% of the time for me.
We checked grounds, pulled fault codes, plugged into the FIC and monitored all sensors while he (successfully) started the car.
It made absolutely no sense. So we got my neighbor...I kid you not this is how we were troubleshooting my car...to try and start the car. It wouldn't start for him.
So I called my wife who was 15 minutes away at a friend's house and told her to bring her set of keys over. (We thought maybe the transponder in my key was somehow to blame.)
She got in. STARTED RIGHT UP!
All. Of. The. Fucks.
So here's where we were at. The car starts and runs fine with absolutely zero issues if Jeff or my wife turns the key. If I or my neighbor turn the key the car refuses to turn over.
So we started turning the key without sitting int he car by reaching in through the open door. We tried gloves. We isolated ourselves from every inch of the car with layers of towels.
Still started 100% of the time for Jeff and 0% of the time for me.
UNTIL!!!! Jeff had the FIC plugged into his laptop via the USB cable. Mind you...NO applications were running. The computer was just on. I turned the key. Started right up.
WHAT THE FUCK?
So I got my Macbook Pro. Plugged in the USB cable. Started right up. Put my Mac to sleep with the cable still plugged in. Car wouldn't start.
So...now...get this...my routine for starting the car is to plug the tuning cable into my Macbook Pro, wake the computer, then turn the key. Otherwise, the car WILL NOT start for me.
So...obviously there is an electrical gremlin somewhere. But it does not, at all, explain why the car will start EVERY DAMN TIME for 50% of the people who turn the key and NOT EVER for the other 50%.
We'll eventually fix it. Jeff is determined to do so when he has the car next week to replace the coil packs and turn up the boost.
Still...I'm weirded out. I've never had a car issue that was 100% dependent on which human was interfacing with the vehicle.
