I know ECR was closed for a time, the weekend I had a chance to go, for repairs to the track. Does anyone, Ken O, know what all the did? Did they fix that big bump in the bake zone going into T6? Just curious.
I hope not, I like getting all manly in there.
There's a Bake Zone at ECR? I like cake...
Not sure what they did.
Sign up for the 9/7 Track day and find out.
If I am bored, I will head out there tomorrow and let you know.
I'm going out there tomorrow morning with the Miata. Probably wont stay past noon. Come on out show me how it's done.
Fair! will be out there testing new aero on the formerly red Mustang.
Ooops. Duplicat post. Sorry.
Well the track was in much better shape than last time I was out there. My driving wasn't. Still pretty bumpy, the track and my driving.
Had three pretty big spins. All three going pretty fast. T4 it sounds like I lifted. I thought I was going to maintenance throttle, but I guess I came off it too much. I still can't figure what happened in T7? I was braking as I usually do and then the back was coming around. I wonder if it was the beginning of my braking issue and the fronts were giving up so I got a lot of rear brakes? If anyone has any thoughts...T11 was pretty scary as I'm usually going close to 100 mph at the brake point. The pedal went to the floor with nothing. I pumped several times and I guess the rears came back a little. That helped me pitch it into the corner and get a slide going. When the pedal went to the floor I thought I was going into the wall. Whew. Enjoy. And don't worry, I've got my flame suit on :-)
http://www.youtube.com/watch?v=jSc7E...ature=youtu.be
Brake Master?
First cracked rotors, then destroyed brake ducting. Now this? Patrick. The brake gods are upset with you!
...or maybe your car is trying to kill you because you have a new automotive muse and it's jealous.
T4: you appear to be at the top of 3rd with the rear of the car loaded up hard coming out of T3, then as you transition to T4, you lift, get back on the throttle, transition the car, and lift again with the car loaded and falling away at the top of the gear.
T7: it appears that you are either braking way too late or you have the brakes biased to the rear too much. What is the # marker where you start braking?
T11: is an overheating issue. :)
^ T4 is a weird one. I'm also guessing untimely weight transfer. T7 looks like you left the braking until too late based on the accompanying soundtrack.
What are the alignment specs?
I would shit my pants if I looped in #4.
What pads are you running?
Usually people make a mess of turn 3 by going wide, running off, and spinning before 4. But you did it a new way...
I like to try new things!!!
The closest I got to having unwanted stuff in my pants was when the pedal went to the floor at around 100 mph going into T11.
Alignment is/was (I probably need to have it done again. Especially with the offs): Front = -2.5° Camber, 5° Castor, 0 Toe; Rear = -2° Camber, 1/16 Total Toe.
In my opinion as someone with FWD experience you need some work on your spin recovery skills. To make a FWD car fast it has to be pretty loose and as such you need to be really good at saving it when it wants to spin. Your corrections were either too much or too little. Next you have to train yourself to stay on the throttle even when you are scared, lifting is the worst thing you can do. In a situation like the T4 spin you would want to stay on the throttle and start looking for the safest place to point the car at. In the T7 spin you could have gotten back on the gas for a second to pull it out of the spin, then look for the safest place to point the car.
As far as the braking issue, there are 2 usual causes for a pedal going to the floor. The first is when the rotor bends a bit due to heat and pushes the piston back into the caliper (generally this only applies to sliding caliper pistons). This causes a soft pedal but a second pump always cures it (some professional race car drivers always double tap the brakes). I doubt this is what was happening to you, more likely you just boiled the fluid. When this happens the pedal will go to the floor and give zero feedback even though you are actually decelerating somewhat. If you look at your video I think this is the case as the car looks to decelerate until you took your foot off the brakes. I would recommend changing your fluid more often and then if it happens again keep your foot on the pedal, press even harder, then look for the safest place to drive the car.
My money is on compound. He has the same brake set-up I have/had back when my car made 250whp, including the ducting and I did not have problems with that set-up running 6-seconds under the SM record on the same track. I bet he's running a pad that's melting down.
Well...I think I RECOVERED from the spins pretty well. :) Especially the one in T4. I went all the way around and kept on going. Now, I could use some work on my spin saving skills fo sho!
I learned that brake fluid goes bad over time even if you don't use it. The car had two days at Hallett on that fluid and nothing else. Also, the front pads were getting a tad thin and both of my brake duct tubing had gotten crushed so no cooling from those (I need to find a new way to route them where my 9" rims don't hit them). I flushed the fluid at the track and went out for a truncated session and all was well.
Rears are overheating; run 60s all the way around, you have a bias valve. Even with 138whp I'm still boiling the rear brakes and losing pressure on cool-down and I run 60s. We need a proper BBK for the rear with a vented rotor, but that will never happen.
Route the ducting through the sway bar. If you need some 2.5" I think I have some extra you can have.
I always check-up on the pedal going into any corner with extreme consequences like #2 at Hallett.
Typically the pedal will not go to the floor when a pad overheats, even if it is crumbling. You will still feel some pedal resistance (since the pistons physically have nowhere to go if the pad is still there and the fluid is good). What will happen is you will step on the pedal and get a resistance, but little change in velocity.
If the pedal goes to the floor or offers little resistance, this is 99.99% of the time caused by boiling the fluid. The fluid turns to gas in the lines, and gas is compressible. Now the pedal can travel because it can compress the gas in the lines far easier than it can compress the piston against the rotor.
If you've ever boiled your brakes, they need to be completely flushed before going on track again. You should also make a habit of bleeding before every event.
To me brake fluid is the single most important fluid in the car. If I skimp on the oil, it will cost me $$$ in the form of a damaged engine. If I skimp on brake fluid, it could cost me a serious injury or worse. I recommend Motul RBF600 or Castrol SRF, with regular (every 6 months or every 2 track events) changes.
When the design temp range is exceeded fluid temps skyrocket. When I ran DTC30s the pedal went to the floor; switching to 60s made it all stop. I suspect this is something to do with pedal pressure and friction. Any engineers want to chime in?
I think it's increadibly unlikely that he's boiling the fluid considering that we have the same brake set-up and such different results.
Besides the fact that altiain IS an engineer, I'll add that as a physics teacher his argument is the most sound. Hydraulic brakes are essentially mechanical in nature, and the brake fluid (any liquid) is incompressible, so it acts as a mechanical component that exerts equal pressure on all parts of the system. The area of the two pistons determines the force multiplication. The only possible explanations outside of his would involve some mechanical portion of the system developing additional play. While I'm not an expert on pad chemistry, I'd wager that they are not liquifying or contracting.
While his explanation is correct, I might be able to clarify: I suspect the culprit is actually WATER that has been absorbed by the fluid, which can boil fairly easily, and can also re-condense fairly quickly when the heat is dissipated by the brake fluid. The less-dense vapor and hot fluid will naturally rise in the system while cooler material is denser and will move down. This might be the reason that brakes which have gone to the floor can quickly recover.
Now, the issue of pad fade is another factor, but not one that should cause a pedal to go to the floor. Exactly which part of his system failed first isn't known, but I think the pedal issue points pretty squarely to overheated fluid on at least one corner. A failure in the master cylinder, piston or proportioning valve orifices would be unlikely to self-correct.
As for similar brake setups and different results, the number of unknown variables in 20 year old cars makes it impossible to say.
With that, let me disclaim that I might also be totally wrong. :)
When a pad goes over it's MOT, it ceases making friction as designed and then additional pedal pressure is needed to stop the car.
http://img.photobucket.com/albums/v3...n/DSCN1355.jpg
http://img.photobucket.com/albums/v3...n/DSCN1356.jpg
When this happened the pedal went to the floor. I swapped pads to Hawk Blue that day and the pedal was fine.
I see what you mean. The pad itself failed and the backing plate bent, so is fits the description of "mechanical portion of the system developing additional play." It allowed too much piston travel as you cooked away the pad trying to generate stopping force, thus resulting in a bottomed-out pedal. I don't think it contradicts the previous fluid argument, but does demonstrate another way brakes can fail.
The best solution to this is to own an NC, which have perfect brakes that never fail. :)
Heh.
Trey, as Mike pointed out, I am a degreed and licensed mechanical engineer with over 10 years of powertrain development experience and a painfully thorough knowledge of hydraulic systems.
Mike makes a good point about water in the brake fluid. Brake fluid is hygroscopic in nature, which means it absorbs moisture. The water does not chemically react with brake fluid. It is merely suspended in the fluid mixture. That means that any water in the braking system that comes in contact with a hot spot - like the back side of the piston - will boil. When it boils it becomes gaseous, and therefore compressible. When any part of the fluid system turns to gas and becomes compressible, your pedal travel can increase. When your pedal goes soft, it is due to localized boiling and compression of the resulting gas volume.
However, even "dry" or fresh brake fluid is a liquid. As such it has a boiling point, and if you exceed this point you will vaporize the fluid. The presence of water merely lowers the effective boiling point by allowing for localized boiling at lower than fluid design temp.
The design temp range of your brake pads has no impact on the basic laws of thermodynamics. Your brakes turn kinetic energy into heat energy. That energy has to be dissipated to somewhere. Most of it is radiated out to the atmosphere from the rotors, but the calipers, hubs, wheels, and anything else in contact also absorb some of that energy.
If anything, once you exceed the design temp range of your pads the energy conversion curve will actually begin to taper off, since the coefficient of friction between the rotors and the pads will decrease and you will be converting less kinetic energy into heat (i.e., not slowing down as quickly or in some cases at all).
This is a pretty simplified explanation. The actual behavior of multi fluid mixtures in closed loop systems under dynamic pressure and temperature conditions can get very complicated. I'm certainly no expert, but I have spent several years designing and troubleshooting very complex hydraulic control systems for mobile off highway equipment.
In short, if the pedal went to the floor, it was because the fluid vaporized. Either that, or you have a leak in your brake system. There is nowhere else for the fluid to go if it remains in a liquid state, where it is incompressible for all intents and purposes.
Okay.
