I know I should know the answer already but, just confirm my stupidity, will ya? ;-)
The stock offset on 90-97 NA is 45mm. The lower the offset number, say 30mm, the more the wheel will jut out under the fender, correct? So the number is distance relative to a vertical plane created by the hub or the fender?
Thanks!
