Get rid of the jack-hammer, for a pocka-pocka-pocka pump!
http://www.aircompressorsdirect.com/...or/p12330.html
What say ye' beeches? Any experience?
Unless you are doing some really heavy-duty air tool work, that looks like overkill.
This seems much more TCB
http://www.harborfreight.com/air-too...sor-61489.html
And if you really do want that powerful of a compressor, this is almost the same price and significantly more HP/SCFM
http://www.harborfreight.com/air-too...sor-93274.html
How big a compressor will you need for OUR new lift? :rolleyes:
The place I bought last year came with a 60 gallon vertical / single stage pump / 135 PSI compressor...
If you're really planning to start using air tools a lot, it's the way to go... the large tank gives you a lot of reserve...
Another Data Point - Heck some of the new battery powered tools can do pretty much anything an air tool can do. (Settle down OZMDD)
I got Ryobi's new 1/2 Impact and was able to bust off the 1-1/4 nuts for the radius arms on my 20 year old ford without any drama. Plus It has yet to meet a lug nut it can't break loose.
Good point, but its usually more about the extended duration of use than the power. IE, sanding, die grinder, paint sprayer, etc. are all much more efficient with a phat compressor.
I am thinking extended duration air stuff and saving what hearing I still have.
Painting the LE?
http://previews.123rf.com/images/vlu...tock-Photo.jpg
Harbor Freight just sent out their 25% coupons that are good through Sunday.
What is the specs on the one you are looking at I'll ask the "Pawn King" if he has anything. ;-)
There is a Porter Cable 60 gallon on the Tractor Supply for $489. Made in 'Murica!!
Thanks!
So is this one - http://www.tractorsupply.com/tsc/pro...pressor-60-gal
the same as this one - http://www.aircompressorsdirect.com/...sor/i9201.html
I have a HF 60g 220v compressor that I have had zero problems with in almost 6 years of ownership. I picked it up with a 25% off coupon when it was already on sale for $400. No regrets.
This one? It's the only 60g I see on their site.
http://www.harborfreight.com/5-hp-60...sor-93274.html
I think they used to make a 60g single stage, but now it looks like they only do the 60 in 2-stage.
This is mine.
http://www.dfwmiata.com/attachment.p...tid=6919&stc=1
How loud are some of these offerings??
Have you asked about compressors over here -> http://www.garagejournal.com/
^Good question, not all of them provide DB specs or even RPM's (slower is quieter). I've been searching and reading over at GJ, lot's of good info for sure!
PS
Thanks Titus...looks like HF doesn't have your model any more.
Barney has been happy with our Sears compressor. Mine is 110 but I see this one on sale... http://www.sears.com/craftsman-profe...9&blockType=G9
My brother in law had a very large Craftsman compressor in his oversized garage/workshop and it shook the concrete foundation when it ran!
Yup. My buddy poured a separate concrete floor just for the compressor. Pretty sweet set up. Of course, he also has an epoxy-floored 6-car garage with several Porsches in it.
^Today's Crapsman ain't what they used to be.
I have owned that compressor for 4 years now. I have not had any problems with it. I can run it down pretty easy with air drills and grinders. I can run it down with a 1/2 inch impact but it takes some doing. If I was still a serious mechanic I would want more, but for hobby use I am happy with it.
Makita MAC2400 Big Bore 2.5 HP Air Compressor is 39% off here:
http://amazon.com/dp/B0001Q2VPK/
After much reading and research, I think I'm going with this one. It's as quiet or quieter than an oil-filled compressor (70db), and will suit my needs.
http://www.homedepot.com/p/Californi...020C/206644539
This one?? http://www.northerntool.com/shop/too...7783_200627783
It looks shorter in this ad??
I like it!! Is it really US Built??
Ten gallons isn't much reserve for more consuming tasks. Will you ever spray paint or blow off large areas or dry off wet stuff?
So once you get it are you going to plumb the airlines in PVC pipe around the shop?? ;-)
PVC?!?! The guys at GJ would have your head! My shop isn't big enough to warrant that, that's why I have one of these.
http://www.harborfreight.com/38-in-x...eel-62344.html
^That too! :clap:
