Preliminary Run/Work order has been set. Based on the current entry level, there will be a 4 heat run/work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event.
Run1/Work3
X, BS, CS, CSP, ESP, STU, SM, SMF, SSM
Run2/Work4
W, AS, ES, ASP, STR, XP, EP, AM, BM, CM, CAM-T
Run3/Work1
FS, BSP, DSP, STX, BP, CP, DP, DM, EM, FM, CAM-S, STP
Run4/Work2
SS, DS, GS, HS, SSR, SSP, FSP, STF, STS, FP, FSAE, KM, CAM-C, HCS, HCR
