Attic Insulation Question
The house is/was losing ground in the 100-degree stuff we were having. HVAC seems to be operating to the best of its abilities. Doesn't tend to lose ground till 2 pm to 3 pm and the house will creep up to a max (so far) of 82 degrees. (AC is set a 77). The weekly updates from my electric provider are showing we are spinning the meter hard!
My AC is hung in the roof joists of the attic. They put a 10' x 10' OSB deck under the AC to give service guys access to the unit.
Figured out it has R19 batts under that OSB. :punchout: The builder blew cellulose insulation everywhere else that the attic is flat.
Recommended R value for an Attic is a Minimum of R30 https://www.energystar.gov/index.cfm...sulation_table
My thought is to pull up the OSB decking and put some R-30 batts in and put the decking back. Then this fall blow in some more cellulose insulation over everything else since it looks like the cellulose have settled over the years.
Does this sound like a logical plan of attack?
