			Posted in Other Cool Cars Hanging Around the GRM Office / 2001 Mazda Miata by Bill (August 10th, 2005)
The cam position sensor finally gave in to the heat recently and caused misfire, Check Engine Light. A trip to Autozone on the way home got me a free OBDII sensor read of code P1345. The temporary fix was simple. Don’t run the air conditioner, and check miata.net. A quick search revealed others who’ve experienced this and a new cam position sensor fixed it. So I called Trussville Mazda and ordered a new cam position sensor.
When the part arrived for ~ $90 including shipping, I spent five minutes disconnecting the battery, unplugging the electrical connector from the sensor, unscrewing the 10mm bolt, pulling out the old sensor and popping in the new one, tightening up the bolt, and affixing the connector. I left the battery disconnected for about an hour while I ate dinner to make sure to wipe away any bad habits the ECU may have picked up. I reconnected the battery and haven’t had a problem since.
