Originally Posted by Titus
			To add to this, it is interesting to note that the cheap universal Bosch sensor does have a plug on the end, it just doesn't match the plug on the car.  The plug does match several late 80's early 90's American cars.  If you search miata.net, you will find a list of cars.  Many go grab a few of the plugs off cars from the junkyard, and then cut the miata plug off of the old OEM O2.  You can then wire up the plug from the bad sensor in your car to the junkyard plug that matches the universal sensor to make an adapter.  You then have plug and play for OEM and Universal next time you need to swap one.  Seems like a lot of work to me, but if you are already going to the junkyard for something, it might be worth while.
