Well,
She's back! And I need to make some SERIOUS room in the garage to fit her in.
Cage is in, kill switch is mounted, seat is mounted, extinguisher is mounted, hard top is bolted in, and window net is in, but no harnesses are mounted yet.
To do: Replace rear finish panel, hail damage repair, wire in the kill switch, install fuel test port, paint the roll cage/interior, and paint the outside.
I've never done bondo on aluminum before. Any special tips or tricks? There are tons of little dings to fill in and sand down smooth - including a bunch of spots the PO did poorly that have to be redone.
I'm going to repaint her a cheap shade of white on the outside and use a rechargeable spray can to finish out the interior (the metal panels that aren't usually painted) in the original factory white paint. I'm thinking the roll cage will be painted a shade of blue to match the harness and window net.
Pics will come later today. It was dark when she came home.
