Originally Posted by
MadMerv
			GG,
Next time you drive the car for awhile, get under the rear (of the car, silly!) and feel the hub on both sides.  Be careful, 'cause the bad one will be much hotter than the other.  If they are equal, I would say it's not a bearing.  Have you checked for a frozen brake caliper?  Miatas are notorious for getting water in the slider and it freezes up.  If this has happened, the inside pad will wear out pre-maturely.  If all is ok on the outboard side, I would guess that a diff bearing is going.  Is there any oil showing where either axle comes out of the housing?  See if you can wiggle the axles and the driveshaft.
