"Baby I am on the road again" ::rock::
I mean after a week on jack stands Ted is back on all fours and tear up the asphalt. I got a ton done.
1.) I was able to get the seatbelt tower brace installed.
2.) I changed the engine oil.
3.) Changed trans fluid,
4.) Change the oil in the dif.
5.) Replaced the PCV Valve.
6.) I got the struts and springs installed on the rear ( look for DIY soon ).
7.) Replaced the right rear brake caliper and rotor.
8.) New brake pads all the way around.
9.) I added some door sil protectors.
10.) I replaced a bunch of missing interior parts.
11.) Added carpet to the gas fill / vent shield in the trunk.
12.) I got started on adding a power antenna.
13.) I replaced the metal panel under the steering column ( missing when I bought the car)
I still need to finish my Interior Light Mod, and the power antenna which I still need parts for.
While attempting to repair a crack I also managed to break the rear finish panel that goes between the tail lights. It ended up in about 50 pieces. It broke into about 4 large pieces and the rest is just shrapnal. I am going to see if I can find a replacement that costs less than an arm and a leg... I checked with the stealership and all I have to say is ::Yikes:: .
Oh well at least I can drive it again.
