Local Link Tuners and HP Predictions?
		Here in a week or 2 I'm gonna take the car to get a baseline dyno, then depending on the numbers I see take the car somewhere for a re-tune.  The guy I bought the car from hasn't touched the Link in at least 3 years.  I'm sure that a pro could probably squeeze at least a few more hp out of it, and make it a bit smoother of a ride.
  I'm looking for a person/shop local to DFW that has experience with the Link, and Miatas in general..  Definitely not somebody who can "figure it out".  I know TDR has mucho experience with the car, but didn't see anything regarding turbochargers or this ECU on their web site.
   The current setup:
    FM built 2.0 with all the goodies.  99 intake, GT2560R turbo, FM IC, FM cat, FM turbo exhaust, 550cc injectors, etc, etc..  Right now the boost controller is set for 12lbs at low, and 15lbs at high.  After replacing the plugs, I don't have any issues with misfiring or losing boost at high rpms, so at least the tune is decent.  I just want to see what extra I can get out of it.  Possibly re-tune the high boost setting for 18lbs, what FM says is the efficiency limit of the 2560.  Eventually I'd like to swap out the turbo with a 3071, but bills come first.  Then if that's not enough I'll end up doing a V8 swap, which is what I originally bought the car for, but it's been too damn fun so far.  Just want some more power!
   A friend of mine is thinking around 15psi I should be around 270-280ish with the 2 liter engine, that sound about right?
