Looking for a 99 sport front sway for my 93 Miata, looking to prep it for ES tire class. PM me if you have one or know of where to find one used at a reasonable price.
Thanks,
Joseph
Thanks,
Joseph
Get the FM front sway. Good bar at a good price. I think a '99 sway would put you in CSP.
LINKIE
pm sent
Anyone know if the 2000 sport is the same as the 99 "sport" front bar? I may get the FM but am trying to get the most economical bar that will do the job for now just to get a baseline setup so I can see what I think.
I love my FM sways!!!!!
I thought the geometry on the bar is different on the early NA's to the NB bar.
See Below.
1992 Bar
http://www.harrisonindustrial.com/im...1992%20Bar.png
2002 Bar (Which is the same as a '99)
http://www.harrisonindustrial.com/im...2002%20Bar.png
I'd go with the 7/8" FM (Addco) bar it work great on my old NA!
I have a 99 OEM sway bar, my car isn't a sport though. but it's for sale.
I'll sell my original bar. It is the sport (HARD S) suspension.
Can anyone definitively tell me if the NB bars even work on the NA? I was told that it should. Also are there any differences between the base, sport and HARD S front sways?
BillyBlaze<-----slowly waves hand from left to right, in front of your face and says "there is no difference ..you want to buy mine"
Really I think the sport is thicker, but am not sure.
I think the real question here is if the 90-93 front sways are the same as 94-97 because we know the '99 sport bar will fit the 1.8L NAs.
mine is a hard (s) btw
Base model '99+ ---> SPORT S suspension
Sport model '99+ ---> HARD S suspension
FWIW, I believe that ALL of the '99+ front sway bars are identical, regardless of model ('cept for the MSM). The rear sway bar on a Sport is 1mm thicker.
I'd just suggest the FM 7/8" front bar. It's the best budget front bar for an NA.
Two suggestions:
- Make sure to either shave the bottom of the urethane bushings or shim the bushing brackets so that the swaybar doesn't bind once the brackets are torqued down. If you don't do this, you will accelerate wear n the mounting points, which are a known failure point on a Miata (especially the NBs).
 - Buy a couple of 1-1/2" or 2" worm clamps at Home Depot. Cut the rubber locating bushings off of your OEM bar, and use the clamps to secure them to the new bar. These bushings are used to center the sway bar and keep it from "walking" too far to one side or the other.
Don't forget the different p/n for a 90-93 vs the 94-97 models.
http://www.flyinmiata.com/index.php?...0%20%201990-93
I'm really tired of tripping over my stock front '02 sway... What's the low bid... How about $15?
So many options, I think I'll just stick with just the front for ES tire class for now. The FM looks attractive but so does a 15-20 dollar OEM alternative if it does nearly the same job and fits correctly plus I've never been one for suspension tinkering. Looks like I need to do some more research to see if any of the NB front bars actually fit my car and then follow what Altiain is saying and go from there.
Any other local 1.6 Estockers with input as to what you guys are using (*cough cough* Jarret)?
Cosmos,
I have Tim the teacher's 03 front sway on my 94. You need a 99+ front bar with the brackets and bushings, then it's just a bolt on. Then you would need some adjustable endlinks for it. I have the gearhead garage endlinks.
