Enkei Racing Series PF01 - $650
***Sold***
These PF01's came off a 2009 Civic Si sedan that I used for autocrossing. I sold the Civic and my replacement does not use the same bold pattern. New these list for $243 a piece on TireRack.com. Asking $650.
The tires would not pass state inspection; however, you could still run a few autocross events on them.
No curb rash. The only blemishes are a few chips from the autocross courses with lots of gravel on them.
Lookup your car here to see if its a potential fit: https://www.wheel-size.com/pcd/5x114.3/
I personally have used them in a 2006 Miata NC and 2010 Sentra SER Spec V
Offset:48mm
Backspacing:5.63"
Bolt Pattern:5-114
Rec. Tire Size:215/45-17
Weight:15.8 lbs.
Finish:Bright Silver Paint
Construction:1pc. Tilt Cast w/Flow Forming
