Event #4 Preliminary Run/Work order has been set. Based on the current entry level, there will be a 4 heat run/work structure. Any changes will be announced at the mandatory 9:00am Drivers Meeting held at the Timing trailer on the day of the event.
Run 1 / Work 3
CS, DS, ES, SSP, ESP, STF, HCS, SMF, AM, FSAE, X
Run 2 / Work 4
AS, BS, BSP, CSP, STR, STU, CAM-T, CP, EP, SM, BM, CM
Run 3 / Work 1
FS, ASP, DSP, STX, CAM-S, BP, DP, SSM, DM, EM, FM, W
Run 4/ Work 2
SS, GS, HS, SSR, FSP, STP, STS, CAM-C, HCR, XP, FP, KM
Car/Class Registration: Make sure your registration for this event lists the car you will be driving during the event. If you signed up for Annual Registration or pre-registered for this event and need to change your car/class, check in during Registration and one of the workers will help you.
See you at TMS tomorrow!
