Check out Mazda/Nissan Heaven. I got an a-arm from them a couple years ago for $50.
after a little excursion due to a durango, i need an upper and lower a control arm for the passenger side of a 93. anyone have some bits laying around or know of a yard they can direct me to?
tia
White n/a '97
There are a few down on 180 near Loop 12 too that would be a lot closer to you.
Also, call Gary at http://www.trackdogracing.com to see if he has any on a parts car.
thanks guys! i got a quote from planet miata but they only had the upper.
I'll give you an upper, but are you sure it is bad? The long bolt will usually bend before the a-arm gives way.
madmerv
yea, its bad. the right front went over a storm drain
culvert and twisted things up a bit out at the ball joint.
I'll take you up on it
contact Bob Stretch
he's bound to have the stuff you need
fixrim @ aol.com
2009 MX-5 STR and track toy
I have an upper a-arm and bolt in the trunk today....free if you still need it.
Merv
thanks for all the offers. i have everything now. ended up with an order from tire rack (bilstiens) and mazda south to finish the shopping list.
thanks again for the offer mad merv, but when i was over at one of the yards getting the lower and they had a stack of the uppers so i grabbed on there.
the upper bolt was bent, had to sawzall off and then heat to remove.. ugh.
hopefully as long as you have one, you will never need one.
thanks again
