I'll take it!
I've got to come up that way tomorrow anyways.
I'll call you in after noon.
Free stuff:
This is stuff I've ended up with over the years. Some was old stuff from when I had Jeeps... Time to clean out the garage some.
I prefer you take it all and that you come and get it - no deliveries you CBs. If you don't want it all then you can give the rest away to someone else.
- 2 quarts Quaker State ATF Fluid. New
- 2 quarts Coastal Power Steering Fluid. New
- 1 quart O'Reilly Power Steering Fluid - 1/2 full
- 1 quart Coastal Brake Fluid - almost full
- 1 quart Prestone Brake Fluid - almost full
- 1 quart Mobil 1 75w-90 gear oil - 1/2 full
- 2 gallons Peak Long Life Antifreeze - 1 new, 1 about 1/3 full
- 1 tube Liquid Nails Tub Surround Glue - new
- 1 Simple Green cleaning kit
I'll take it!
That liquid nails is great on carpet, or really a lot of stuff.
I got a tube of it when the covering on one of my speakers started coming off.
99 Miata Black
Thanks John!
Lock 'er up, the stuff has been picked up.
