If you install an intercooler in front of the radiator, it heats up the air before it goes through the radiator. This makes things extra hard on the cooling system. Add an A/C condenser and things keep getting worse. Adding a bigger radiator helps. Adding ducting to maximize the air going through the radiator (rather than escaping around it) helps. Some still have problems. I have all of the above, and I still have problems in stop and go traffic when it is over 90 out and the A/C on. I have never heard of anyone having any more problems once they have added a pair of high CFM fans. One of these days, I will go that way.
weak point and I never was able to fix it, even after $1,500 worth of Easter-Egging the problem. The other part of the reason I ask is that I'm getting reasonably close to throwing down for a blower - well, ok, I'm mere months away, but still.
