43 views and no advice.. guess that means I’ve covered everything.
Got a NEW motor comming
Replacing the motor mounts w/ some competition mounts and replacing the radiator with an aluminum PWR. What else should I replace??
Also, while I've got the transmission off I was planning on doing a new ACT clutch and flywheel. What else should I do w/ the trans besides new seals & gaskets?
Anything, I was going to mention, you already said you were doing! Congrats, hope it's back up and running soon!
Since it's your money, go ahead and get some SPAL fans.
Smile![]()
I think you need to donate your seats to me
				Hope I'm not stating the obvious by saying heater hoses.
I thought "competition motor mounts" meant "more vibes"...
Just make sure you don't hook up the gas lines backwards.
BTDT... It shoots gas about 12 feet when you release the pressure on the line.
Thanks guys.. and yea I do expect to get a little more vibration from the Mazdaspeed mounts.
I would also install new shift boots and make sure to replace the trans input seal and throw our bearing and maybe rebuild the slave for good measure. On the motor new belts hoses and water pump are a given.
Coolant re-route since it's out. If, you have power plans in the future.
Chris
http://austinmiata.com/
Very nice!
Smile![]()
Purty
do the coolant reroute if you plan on tracking it. Looks good, and good to see a few more turbo miatas in town. Is that a gt2554? Its a cute little guy, lol.
I'm happy to help if necessary when you decide to take the MS plunge.
If you don't mind me asking, what does a new engine run? My wife's 99 engine appears to be toast, so I'm trying to decide what to do, either rebuild, or buy a new short block.
Billy
98 Prelude - track car
Former 99 Miata owner
I'd probably email [email protected] He has a bunch of spares lying around if you just want to swap in a fresh one. He has a connection too if you want to get something built.
