I would suggest you check the LONG bolt in the upper a-arm also. I bet it is now an "S'. Loosen the nut a few turns, then see if the bolt will rotate. If not, it's bent.
Does the car have power steering or manual? The tie rods are different and are NOT interchangeable.
 Let's go racin'
