Speakers showed up today!
Quick question how do you tell what the Positive (+) and Negative (-) wires are on the speakers?? Last owner installed the current speakers poorly...
You could check the phase polarity with an ohmmeter, if you have one, if not you could use a test light (comes with most stereo installs). Or, worse case, you could just hook the wires up to the speaker without checking. There will be some sound degradation, but in the LOW LOW decimal range, unless you have amps/crossovers it won't matter.
Good stuff TexasCoder!
Google found me this also - http://mazda-speed.com/faq/audio/#90
Sounds much much better!!
Thank you! I am new here so I want to contribute when I can
That is a great find on the wire color codes! I printed that bad boy out and added it to the miata's log folder. You know, I just glanced through my shelf out in the garage and found my DEI Schematics/Wire Code book for 1989-1997 Imports. Sorry man, if I had been thinking I would have checked there for you first. I got so excited about being able to contribute to the forum that I lost all common sense :)
POS Racing, after a month, how do you like them?
