PM sent!!!
Asking $400. Works perfect.
The PerformanceBox is suited to:
* Straight-line performance: 0-60, 0-100, 60-130, 60-0, 0-100-0, ¼-mile etc.
* Horsepower calculation: calculate both wheel and flywheel HP.
* Lap Timing: using GPS, there is no need for an external lap timing beacon. Accurate to 1/10th of a second.
* Speed and Compass display: use it as a super-accurate speedometer, updating 10 times per second, to calibrate or verify your vehicle's speedometer.
No matter how you use the PerformanceBox, it logs your speed, position, G-forces, and distance to its memory card ten times every second for detailed analysis in the included software.
View your performance and lap data on the PerformanceBox's built-in display, and log all your data to the SD memory card. Saved data files can easily be stored and compared, to see the difference between cars, drivers, parts, or setups.
http://www.vboxusa.com/performancedr...ormancebox.php
