http://www.partsgroup.com/store.aspx...ta-Misc&Page=2
down at the bottom
My horn has stopped working in my 1994 Miata. I checked the fuse and the fuse is good. Someone told me to go online and look for a OEM horn as a replacement. Does anyone know of a good website or store to shop at to replace my horn. Thanks.
down at the bottom
Time to upgrade to HF air horn! ... or you can buy my OEM horn from my 99.
Thanks for the info. This store is in Alabama about ten minutes from my parents home. I gave the info to my father who has a 1990 Miata.
I found a horn on this web site I'm gonna order from http://www.mmmiata.com/catalogsite/electrical01.php. Thanks.
Get the Wolo Bad Boy!
http://www.northerntool.com/webapp/w...6940_200326940
or you can pick one up at the Northern, at 121/183 split.
http://www.northerntool.com/stores/bedford-texas.htm
There's a Northern Tool in Lewisville on I35-E just south of Business 121 on the south bound access road.
It'll be closer to Carrollton than 121/183.
You really should look into a nice air horn. They're not expensive, and they're easy to install. Plus, I'm sure you could find some install help around here pretty easily if you need it.
Here's the horn I'm running: http://www.thompson-automotive.com/Air_Horn.html
I'm also in the market for a new horn...
http://www.northerntool.com/webapp/w...9189_200319189
saw this, seems like a good deal
Stebel Nautilus air horn. Compact and self-contained. I run them on my bikes due to space. It will get ur attention no problem. I've been meaning to get one for my miata
http://www.google.com/products?q=STe...N&hl=en&tab=wf
You can also usually find them under a different name in the big box auto parts stores. I usually find them at O'Rileys
2004 Saturn Ion Redline
Wrong Wheel Drive
1992 Grey MX-5
Right Wheel Drive
I'll give you an OEM horn! Both of you.....
I found this site http://www.wolo-mfg.com/
