Get the seat. Torsens will always be around to upgrade later.
So I have my lovely 2004 5 speed base model...open diff.
I was considering replacing my pos foamectomied stock seat before the next autocross I plan to attend...
But I was just browsing for torsens, and came across some not-too-shabby prices.
But the question is, is it worth it? To spend $500 or so, and have an off speedometer, and a bit slower acceleration....when usually, the open diff isn't a noticable problem?
I know autox will make the open diff show its weakness more than the street - but my question is, am I even at the level of driving that a torsen would be $500 in benefit to me - more so than $300 or so on a much more comfortable seat I'll get to use daily.
Smile![]()
I agree that the seat should come first, but based on my one and only ride in an open-diff'd Miata, I could not believe how badly is needed a diff exiting turns. I felt like I was in Ken O's Mini. Granted, this car has crappy tires, but it was also a 1.6 and that thing was always spinning the tires exiting turns.
Torsen. Save the money and buy it at a good price.
Like Hardtops, they can be found at a non-crack smoking price if you're not in a hurry.
You can also do the RX7 clutch-type LSD for mad TCB points (though I think it's more recommended for road racing or drifting, OR the other way around). Either way a RX7 unit is usually cheaper than a Torsen.
Chris
http://austinmiata.com/
Seat first! However, a $500 Torsen is not a bad price if you can get it from a low miles car. That was what I paid several years back for one with 30K miles on the clock.
				You'll be much faster with a torsen and it will be much easier to drive.
Are you trying to stay in a particular class for autocross?
No I am not trying to stay in a particular class. Will me having coilovers on my car now make my open diff work better, or worse? I'd think better but I could be wrong.
Still a toss up unless I find a sweet deal on a Torsen.
I don't know if it's any relevance, but I still have the ass pad I cut out of my seat when I did the foamectomy on my stock seat. It's from a 93, but still has it's resiliency. It might fill the hole, or could be trimmed to fit for the mean time. (I don't know how different the NB seats are in this regard so it might not work) Let me know if you want to try it, you can have it.
The ass pad is semi livable on my seat, the lower back is the problem...no matter how much memory foam I throw at it or take out, it's never comfortable.
Should have never messed with it.
As I stated in the other thread, go check and see what the dealer will charge for the factory molded piece of seat foam. As long as the upholstry was not cut off at the bottom you should be able to make it back to new. It ran me less than $90 to do the bucket seats in my Nissan back 7 years ago.
