no complaints about boost buggies here in STU.... it's the stupid ST Civics![]()
Not sure for the M3, but in SM I can swap cams, turbo, and all sorts of other stuff.
From Glen's M3, I'm pretty sure you could go FI in SM if you wanted to... in addition to cams.
You'll have to get real r-comps to be competitive though.
Put the stock exhaust back on yesterday. It's so nice and quiet now. No more ear plugs.
New tires next.
For the people thinking about exhaust next year don't forget about the new 100 db maxrule in SCCA next year at nat. events, about time. I don't know if we will have a local limit.
I think it will be 100dB at 50 ft. As much as I hate the hard limit and think it will be a pain to enforce. I am very much in favor of the rule because of a few cars that are WAY to load and nobody being able or willing to enforce the current muffler rule.
My left ear still rings from being in the wrong place when a 3 rotor Miata started his car in gird 2 years ago.
Screw cams in SM just do the Active Autowerks Supercharger then you have 500hp.
You can do headers....you just can't buy them off the shelf...
My mods:
AST 5300's with DLC coating on the inverted shafts
Camber Plates
Work out the exhaust system
Sparco seats
Intake
Harness bar
Motor Mounts
Trans Mounts
ECU Upgrade
Sway Bars
Start testing tires....
Stuart F. Maxcy
STR 82
NC Miata
I learned this the hard way.....
Take all of your valuables out of your car at night. This includes taking the mounting hardware off of your windshield or dash and hiding the power supplies. I lost over $ 1,000 to a thief with no hope of recovering my items and to top if off they smashed my window in the rain and my truck got soaked. Let my loss be your learning experience.
- Install new front bushings - Not done.
- Replace timing belt, tensioner spring, and associated seals - In progress.
- Replace water pump - In progress.
- Replace ignition coil - Done.
- Replace oxygen sensor (causing CEL) - Done.
- Replace cat-back exhaust - Cancelled.
- Plus, I have several other chores, like adjusting my top latches and window seals. - Not done.
I've looked at the stuff I need to buy on the interweb several times...... Does that count??
