							What you are looking for is the Magellan RoadMate series.  They run the same software as the Hertz system.
I have the 700, but it is also available in a 500 and 300 model.  The 500 and 700 are the same case, processor, software, etc.  The difference is in map storage.  The 700 has a harddrive loaded with everything for the entire country.  The 500 uses a memory card that only holds a region of data.  if you are on a long trip, you will need to hook it up to your laptop every 250 miles to change the maps.  The 700 can be found online for around $900, and the 500 can be had for $800.
The 300 is new.  From what I here, it uses memory cards like the 500, but has a slower processor and lower quality maps.  It's upside is a better screen and a lower price(under $600).
		- You may not post new threads
		- You may not post replies
		- You may not post attachments
		- You may not edit your posts
	Forum Rules
