Nothing special. 3 bolts (14mm maybe) on each side near the rear of the doors and then the 962 10mm nuts holding the rain-rail on.
				Anyone know off the top of their head what tools are needed to take off an NB top frame and all?
				Is the soft top frames interchangeable from NA to NB?
Yep.
				Take it easy as you pull the rain rail so you don't crack it.
				Yea should be fairly easy to get all this off I think I have read 10 tutorials on how to remove it and a few vids too, and every one of them said that same thing be careful with the rain rail :P.
				While the frames will physically fit between the NA and NB, they are not identical. The NB frames have the spring loaded last bow (and straps) which allow the top to be folded without unzipping the rear window (NB's don't have zippers). Just thought you should know.
Currently Miata-less... 2007 Brilliant Black NC PRHT, to replace 2006 Winning Blue NC, to replace 2002 SE, to replace 1993 LE #1322 and so on and so on...
				Yea, I knew the differences for lowering it, which is why I wanted an NB top rather than my NA, but I didnt know exactly what part made it able to be so much spiffier :P.
But went and got it yesterday and the rims Im wondering whats up with the car it was in perfect condition, she says that the engine blew but I tried to explain to her she could sell it for so much more than parting it out.
Does anyone know if you can drill and install these springs to an NA top frame? I'm still getting the kinks worked out of my Robbins glass window top, seems like those springs would help alot with the retracting.
				Yea im hoping to get that and my fender put on this weekend, got this spiffy new key off ebay since i only had the spare, im going to get cut today.
If anyone wants to help Id gladly appreciate it![]()
Also the top needs to be repaied just a lil but i dont knwo how to go about doing it, around the bottem by the passanger side it sepperated form the frame a lil but tore suggestions?
				Forgot to mention would provie Wingstop or Buffalo Wild Wings (whatever closer) and beers if someone can provide a garageGF has ours full of junk
you could use what some vandals decided to use on my car....a knife....![]()
