Results 1 to 6 of 6
Thread: Blown main fuse
    Unhappy Blown main fuse
    My '95 (98000 miles) is unable to start due to a blown main fuse. The car worked normally the day before but could not start the following day. Any suggestions on why or what to check before I replace the fuse? Also, the fuse is stuck in place. The other fuses can unplug easily except this one. What's the easiest way to unplug this fuse? Thanks!
    Default Blown fuses
    OK....I found out how to replace the fuse. It was not 'stuck' after all
    Nope. Bolted down.
    As for blowing the fuse. It usually has to be a short. I blew that fuse when I accidentally grounded the power wire to the alternator once. It's an 80 amp fuse so I'd certainly find the source. Check to make sure your battery connections are tight and the battery is bolted down securely.
    I had one blow years ago and never did find the cause. ?????
    Smile
    Default Blown fuse
    Thanks guys. I think I may have messed up when I tried jump starting the car with the dead battery. I replaced the fuse and all is well
    That'll do it every time. Gotta watch those battery leads!
  1. Blown Subwoofer
    By black roadster in forum Parts is Parts
    Last Post: 10-17-2008, 10:05 PM
  2. main bearings
    By Mouglie in forum Parts is Parts
    Last Post: 04-27-2007, 03:06 PM
  3. Twin-Blown GTO Show Car
    By johnwag in forum OTM Tech and Chat
    Last Post: 01-15-2007, 03:33 PM
  4. blown head gasket?
    By jjmiata in forum Miata Tech and Chat
    Last Post: 05-05-2005, 08:17 AM
