Check with Gary at TDR. We are about to pull one out of our Lemons car.
Anyone have one for sale for a reasonable price? No leaks or missing parts preferred Thanks.
Blah blah blah!
TDR is Track Dog Racing. Gary is the owner.
http://www.trackdogracing.com/website/contact.htm
I have one in a 1990 model that I am parting out. Drove the car before I decided to part it out. 138000 miles, new timing belt, new water pump, no issue with key way. $100.00 if you pull it out.
Thanks for the info, I emailed Gary.
Cliff - If he doesn't come though I'll consider your offer, thanks!
$150.00 if I pull it out and you pick it up in Garland
Well, that's a hell of a deal, is there any installation issues that you know of with installing the short nose crank motor into a car that wasn't originally? Gary has no good motors at the moment, so this might be an option.
Engine has been sold-Thanks
Bump.. anyone know if a motor from an automatic will work with the manual trans?
Yes, it will work, but it has less power as the engines for the automatics had lower compression. That is a good thing if you ever want to add boost, but stock it will leave you a little slower than before.
Bump for anyone else? I thought these motors were supposed to be cheap, all the junkyards want $600-800. I was thinking closer to the $400 range. :P I might just bite the bullet, I want to get this done over the long weekend.
