Thanks for the tip Gary! I've read that 32mm nut is torqued at over 200 ft. lbs!Originally Posted by shuhart1
Sam,
Unless you are having problems with your axles you do not have to take the axles off at the wheel hubs do install the rear end. That hugh nut is almost impossible to break loose. Just remove the bolt on the lower half of the wheel hub and then using a crow bar or similar, snap the axles out of the diff. There is more to this, but this should speed things up.
Gary
Danger!!! This Dog Bites.
www.trackdogracing.com
Congrats! How'd the install go???????
It really wasn't too bad. Took about 3 hours or so. (We ended up swapping the entire carrier assembly instead of just the guts.)
Cool
You mean you have to be in water to spin those tires? You need a blower bad!
Gary
Thats what I was thinking!!!Originally Posted by shuhart1
(oh wait I need one too!)
I've got mine , but it is sitting on the work bench right now.Originally Posted by Majik
That does you no good... and no good for the rest of us either... now put that damned thing on!!Originally Posted by Titus
Must get the header in first. I should have it back from the Ceramic Coater tomorrow. Now I need to find a short O2 sensor (Ataim, you get that part number?) and I need to get a new manifold gasket. Autozone doesn't stock it, nor Pepboys. I am debating ordering it online or trying to get to a stealership during business hours.Originally Posted by Treibenschnell
Go to Town North mazda, ask for Cary and ask for the Track Dog Racing discount. He will give you anywhere from 10 to 20% off.
Gary
Thanks Gary!Originally Posted by shuhart1
Wow... I am surprised that I have yet to be arrested for thread hijacking!
don't get beeyawtch, or someone might! :POriginally Posted by Titus
Are they cheap?Originally Posted by shuhart1
I hear the first ride is free.... then he has ya hooked!Originally Posted by sammm
I was hoping I could be the first one to get the newly anointed Bean to goOriginally Posted by sammm
