just don't get a harness bar or you will brake the glass. both work styles will save your life.
Tomorrow morning I'll be going to TDR to order my Rollbar. I have a zipper-less glass top/frame off a Nb on my Na . I plan on getting the Hardcore Hardtop M2, But I am Undecided if I want a Single or Double Diagonal. What do you guys prefer and why ?
I've got the double diagonal on my M2 Sport and it does a pretty good job of blocking the view out the back (mainly with the top up). But after a year and half with it, I'm used to it.
EDIT: +1 to Jeff's post... harness bar won't work with the glass window.
I had a M2 Sport in my old '99. No diags with harness tabs. When the top is up, the roll bar is totally 'hidden' and doesn't interfere
with rearview vision. The glass rear windows are small enough as it is.
The single diagonal bar always looked a bit odd to me.
Not that it matters to the discussion, but I have the double diagonal M1 bar, and I don't even notice it in the rearview mirror. It obviously does block a small portion of it, but I used that "deadspace" for my WBO2 readout, so I notice it even less. It's just a matter of if you're too lazy to move your head an inch to either side to check the small part that gets blocked in the mirror or not.
My wife keeps telling me go with the DD so I may take her advise for once since shes usually right about majority of the stuff we disagree on
Having an MSM with the M2HDHC hardtop bar, my single diag. does catch my top and has starting pulling the stitching right at the corner of the glass window. I would go double diag. if I were to do it again. My '97 had a custom M2HDHC hardtop bar with double diag. and had no contact issues with my M2 top. YMMV
2013 Mazda2 slushbox daily
I recently added a M2 Sport with double diagonals to my NA. It doesn't bother my rearview vision. CarCar's raccoon accident and going to the track occasionally motivated me to get a rollbar.
you can put the top up with out getting out of the car with DD, single it's a LOT harder.
get a Boss Frog Double Max, it'll make putting the soft top up and down easier and it's scca legal.
I don't get how it's different at all though. You guys start by going through the bar or something? I guess my arms are longer than yours? I just prop myself up a bit and reach over the top of the main hoop of the bar - i.e. I never go "through" the bar. Takes 5 seconds if I haven't done it in awhile; 2 once I get used to it again.
I ordered the hdhthcdd. Today can't wait for it to get in.
While seated, I reach under the bar with my right arm and pull it up as high as I can until my right arm contacts the top cross bar and then grab it with my left arm and pull it closed the rest of the way.
SOLD - '91 BRG
Ah, never even thought to do that since I'd have to maneuver around the cross bars. ha
*Update*
The bar came in and the guys at TDR did a great job installing it I couldn't be happier !
