Results 1 to 2 of 2
Thread: Headlight Retractor Motor.....Help
    Default Headlight Retractor Motor.....Help
    I have a '93 NA. I'm asking for help to determine why my Headlights go up (electrically)......but, won't come down w/o manually lowering it with the knob. This occurs every time. Do I need to replace the motor, relay, switch...etc?
    Shazam
    If the dash switch is disconnected, the lights won't go down. Could be unplugged, a break in a wire, the switch itself, et al.
    Some times you'll hear and feel a click when you plug that button in, but it can still magically work itself loose. If you just had the radio bezel out for some reason, chances are it's just not fully connected. If you haven't touched anything there recently, and this just started happening, you might very well need to replace the switch.
    I've also heard that there's a flasher under the dash panel under the steering column, by the door buzzer, that will cause the same thing. I've personally never found that to be the cause, but that doesn't mean it can't happen.
  1. $8.99 Headlight Restore
    By cam76034 in forum Miata Tech and Chat
    Last Post: 12-12-2009, 03:53 PM
  2. FS: 99-00 LH Headlight
    By Darron65 in forum dfwMiata.com Classifieds
    Last Post: 05-22-2009, 10:58 AM
  3. 99 LH Headlight
    Last Post: 02-28-2009, 08:57 AM
  4. Floppy headlight...
    By trickyrix in forum Parts is Parts
    Last Post: 02-06-2007, 01:26 AM
  5. Headlight Out
    By riverracer in forum Miata Tech and Chat
    Last Post: 12-16-2005, 09:56 AM
