Got to see if they will fit, but I'll most likely take them.
I have a set (2) that did not fit the M3. Went with a different setup.
Asking $40 for both.
From Pegasus Racing
Air Inlet, Small Bumper Mount (1 Outlet)
Computer Aided Design (CAD) and wind tunnel testing have been combined to produce these ducts. Attention to detail results in maximum air flow with minimal drag. They are molded from tough, high-impact black plastic. An integrally molded flange (approximately .75" wide on most ducts) makes them easy to install in body panels or air dams. The outlet nipple is sized to fit our 3" air ducting hose. Approximately 9.5" x 5" including flange.
M3 is always the answer.
Thomas![]()
V-to-the-Dub
BTW, I'll give you two-fiddy. :)
Thomas![]()
V-to-the-Dub
If thomas can't use them I want next dibs. Shout me a message as I don't check the site as much fitting the day ant more
Blah blah blah!
Measured the car, these are too big. Thanks for holding them.
Mike, they're yours.
Thomas![]()
V-to-the-Dub
Hey Ken o have you already upgraded to the CSL brakes?
http://www.turnermotorsport.com/html...ID=34000429573
Not a bad price considering they come with new calipers.
My rears are still OEM. The fronts are StopTech 40, 4 piston calipers.
This seems to be a good combo. I added the ducts because I the rotors were cracking before they wore out. The guys at StopTech recommended the ducts.
