Results 1 to 16 of 16
Thread: Hard Dog Door Bars
    Default Hard Dog Door Bars
    Anybody ever use thes bolt-in door bars? Are they worthwhile? Do they stiffen the frame much, or are the bolt on frame rail stiffeners better?
    While I don't have them, I have heard several people with them compare their stiffening ability to that of the FM frame rails and butterfly brace. I have the frame rails and can confirm they do make a noticeable difference.
    Worth the $$$
    Speed
    I've got them on my 90. I never tracked the car without them - had them put in when I did suspension and roll bar installsright when I got the car. The chassis seems plenty stiff with the roll bar and door bars installed. I'd say that based on the geometry involved that they'd do the same for stiffening that the frame rails do but for less weight (albeit higher and further outboard) - they make pretty big triangles from the B pillar up to the floor at the A pillar.
    Chris
    Dec 2006
    dallas
    i tool a set off a friend NA to barrow and installed them in my NB, they only fix because my car is stripped but yes they are so very much worth the money.
    Quote Originally Posted by jeff_man View Post
    Jeff_man say what?
    jeff_man
    Lost in translation!
    Let me help. I speak jeff_man.
    He fabricated a set, using a set from an NA that he borrowed from his friend. He installed the set on his NB. They only fit because the car is stripped. He endorses the product and believes it is worth the money.
    M3 is always the answer.
    Driver Keifersmith's Avatar
    Aug 2008
    North Richland Hills, Tx
    LOL!! I almost fell out of my chair.
    90 Red NA
    91 Red NA
    99 Triple Black NB "Dimples"
    Let me help. I speak jeffanese.
    fixed.
    I figured that you would want to avoid the extra weight in DP.
    Too bad this isn't NASCAR... He could save weight by only installing one side.
    Turns out DP is not as light as it looks! Under current rules, my car would need to weigh 2073 lbs. (That is with a 75 lb penalty for wheels wider than 7"). Last time I weighed the car it was at 2025! Rule changes asr in the works that will lower the min. Weight for my car down to 1924 lbs, but that won't take effect until 2012. DP cars look all stripped out and light until you look at the passenger floorboard and see all the ballast plates!
    Quote Originally Posted by Mark52 View Post
    You gonna get Onething to ride along down there?
    That just hurts.
    Gary installed them in my 90 and the difference was obvious. Not a bad safety item either.
    Bobby
    RED RULES!
  1. WTB: M2 Hard Dog Hard Core Roll Bar
    By apex2apex in forum dfwMiata.com Classifieds
    Last Post: 04-16-2010, 10:42 AM
  2. Hard Dog Hard Core DD Roll Bar for sale
    By smartmx5 in forum dfwMiata.com Classifieds
    Last Post: 06-18-2007, 01:07 PM
  3. FM Sway Bars
    By Bacon in forum dfwMiata.com Classifieds
    Last Post: 05-10-2007, 07:32 PM
  4. TCB Deals on Hard Dog Bars?
    By Treibenschnell in forum Parts is Parts
    Last Post: 05-18-2005, 09:05 PM
  5. Roll Bars - What do you have? What do you want?
    By sammm in forum Parts is Parts
    Last Post: 05-04-2004, 07:32 AM
