Results 1 to 7 of 7
Thread: Coolant leak
    Default Coolant leak
    Just drove to Sonic, pulled in and smelled that nasty coolant hitting something hot smell. HAd fingers crossed it was the old beater Chevy Blazer parked next to me. Got home and unfortunately it was me. Popped the hood and apparently it is leaking possibly from one of the two hoses from the driver's side firewall but I cant tell if it is a hose or where it connects to motor. Have it cooling off now so that I can take off the heat shield and get a better look. Any thoughts or suggestions to look for?
    Chassis Designer
    Apr 2009
    Keller, TX
    You might want to check the floor on the passenger side. If the carpet is wet, or if there is a puddle on the floor pan, it might indicate a heater core problem.
    I'm a big fan of AutoZone's free Coolant Pressure Tester. It pinpoints the leak with all the pain of getting hosed with hot coolant!
    http://www.dfwmiata.com/showthread.p...hlight=presure
    Found the leak. Heater hose that runs to the back of the motor under the coil pack area. Looks like about a 1/2 inch split. I've already read about the senstive copper stubs and the need to cut them instead of twisting and pulling. Looks like I will be swapping hoses tomorrow.
    Looks like it might be easiest to pull the CAS off in order to get at this heater hose. That means replacing that O-ring. Is this a dealer only part or is something available at the various autoparts places? It's not that I am looking for cheaper than a dealer, I just dont want to jack with going to a dealer to get it if I dont have to.
    Nothing special about the O-ring. I don't know the size off the top, but it's on here somewhere.
    EDIT - Here ya go -
    http://www.miata.net/garage/cas_oring.html
    Thanks. I got to looking after I posted, imagine that!
  1. Coolant leak!
    By goofygrin in forum Miata Tech and Chat
    Last Post: 10-21-2010, 06:48 AM
  2. Coolant leak 93LE. Shop suggestions.
    By 1966 in forum Miata Tech and Chat
    Last Post: 04-17-2010, 08:29 AM
  3. please help! coolant leak
    By moosemonkey in forum Miata Tech and Chat
    Last Post: 11-02-2008, 06:34 PM
  4. Locating elusive coolant leak
    By cam76034 in forum OTM Tech and Chat
    Last Post: 05-16-2008, 06:42 PM
  5. Interior coolant leak
    By Majik in forum Miata Tech and Chat
    Last Post: 02-26-2007, 12:16 PM
