Here are some great how-to's pertaining to car wiring Linke
Give me a sec an I'll try to find the article you need
How can I reduce a 12v line powering LED gauges to a lower voltage to reduce the illumination? I have it connected to the dimmer switch but the LED is much brighter than the other lights.
M3 is always the answer.
'06 RSX Type-S NBP
'06 RSX Type-S NBP
They have 12v LED in them. But the delta from bulbs in the OEM gauges to the LEDs in the gauge is too much. When I turn the dimmer all the way down the LEDs will dim but are still to bright.
What about heat generated form the reduction?
				Cover the LED: http://www.leddim.com/
Good idea but it would block the gauge. I thought about amber tint but think it would be tough to see on the track.
A 560 Ohm resistor will only disipate about 180 mW of power, so heat from a single little resistor should not be that much.
Here is a little calculator that might help you determine exactly how much resistance you need, sepecially since I'm not sure how many LED's there are in the circut.
'06 RSX Type-S NBP
Going to try and go to RS tomorrow to pick up a resistor. I have 3 gauges, each with and LED powered from one source, power is in sequence from gauge 1 - 2 - 3. I connected a 6v battery and the illumination was perfect.
Do I pickup a 560 Ohm resister or a 300 Ohm to drop to 6v and wire it in to the positive before the first gauge?
