Sorry nobody could help with this. I would try the mazdaspeed forum and see if they can help. Other than that, a call to trackdog racing or Flyin' Miata may help. Good luck.
I was at the track on Thursday and I was adjusting my boost with a manual boost controller. I was running great at 10 PSI, but decided to dial it back some to see how it would feel. I turned it back up and for some reason my boost shot to 15 PSI during a run. When that happened my car shut me down by dropping to 4000 RPM and only allowing me 3-4 PSI of boost.
I dialed the boost back down with my controller, but no matter where I put it its the same thing. 3-4 PSI and once I hit 5000 RPM a soft rev limiter kicks in and I can't go any faster/higher.
Yesterday I unhooked the battery for an hour hoping that would reset the stock ECU and that would solve the issue but no luck. Any ideas? My car is slow as X-Mas right now, and I am at a loss.
I was wondering if my boost controller broke and it putting to much boost out and the ecu is constantly going into limp mode. Does anyone have a boost controller I can borrow to test that theory?
Or maybe i need to do something else to get it out of limp mode?? This is my first turbo so I'm really not too experienced.
Thanks
Resetting the ECU entails holding the brake pedal down for around 15-20 seconds with battery disconnected and then drive readies have to be done on earlier models. As for the MSM, no clue. Sharpie's suggestion is where to start. Keep us posted...
I use to worry about money; but then realized I don't HAVE anything to worry about.
I got it figured out. I guess I upped the boost a little too much. It blew the Throttle Body Inlet hose off. LOL. I bought some new clamps and got everything strapped back down and all is good. It wasnt the ECU at all but I wasn't putting any pressure into my throttle body.
I plan to replace the intercooler and pipes, as well as my blow off valve in the next few weeks. That should allow me to turn things back up. After that I'm looking to install a new downpipe. Lots of fun projects coming up.
miataturbo.net
stop being cheap and get a electronic controller
Gonna say, an ECU can't make a turbo produce less boost than the wastegate setting. Unless there is some kind of controlled boost leak produced especially for this purpose, which I have never heard of any OEM doing. If the MSM wastegate is 7psi, you can't be limited to 4psi unless there is a physical problem, which is almost always a boost leak (could be a bad turbo, etc, but is more than likely a massive leak in the plumbing somewhere).
My best advice to a new turbo vehicle owner: Get or make a boost/vacuum tester, learn how to use it, and use it every time you change the oil especially as the car gets older.
hey i mean electronic so it doesn't have to do guess work with how many turns = how much boost. I'm giving you the benefit of the doubt that your way smarter about turbo stuff thin this guy and that you know how to adjust your boost properly.
it pulls a butt load of spark so your turbo wont spoil in return
Eh, I'd be surprised if it pulls *that* much timing. Every factory turbo car I've ever owned has a limp mode that pulls a ton of timing but still only reduces boost to the wastegate setting. But those were all early-mid 90s cars, so the MSM could very well do what you're saying. I'd still be surprised.
That's the point of a limp mode...My Z's limp mode was literally ~50rwhp less than stock power. But it still would hit wastegate boost pressure, that is my point. All the other factory turboed cars I had were the same way.
But yeah, I know the MSM ECU is screwy on a few other things, so I guess I can see it happening like that. Still seems odd to me.
Regardless, that wasn't the problem, and it's fixed now. So this whole conversation is moot.
