I calculated the brake line capacities on the back of an envelope. Being generous, the master cylinder hold 2.6 fl.oz. I do the right rear first, the line hold 4 fl.oz. so I stop after 2 fl. oz. and refill the master cylinder, and bleed another 2 fl. oz. and refill. Next, I do the left rear. From the "y" to the left caliper, the line holds 1.7 fl. oz., refill the master cylinder. Next, I do the right front, 2 fl. oz., refill. And finally, the left front, 1 fl. oz., refill and you are done. I use an old baby bottle to measure.
By doing this, I don't need to jump up and check the level in the master cylinder, I know when to go refill it.
Also, Track Dog Racing has this.
PS: Although you haven't ask, I use Ford High Performance Dot 3 brake fluid. Dry boiling point is 550*F, wet boiling point is 284*F, so I change often. It's also TCB.
