Page 2 of 2 FirstFirst 12
Results 21 to 33 of 33
Thread: My little project car
    Would you be a dove and take a picture of your CKP sensor on the car? I need to hook them up on both engines but I've never seen the mount before and don't really know what I'm doing. I have the same clutch. You'll be lucky to "break it in" on stock power. I ran that clutch for about 1-year and 50 track hours at stock power and when I swapped engines it slipped for a day...I'm calling that day "break-in".
    Engine Builder
    Jul 2011
    Denton, TX
    Quote Originally Posted by Vashthestanbeto View Post
    Awesome! please, share with us how daily-able it is once you drive with it a couple days. I am pretty curious. The ClutchMaster Stg.1 on the(no longer really mine) Gen coupe was heavy and very non-linear in engagement, I've always wondered if other aftermarket clutchs are going to be similar.
    So far it isn't that bad, It doesn't feel heavy like some of the performance clutches I've had in the past...It is a bit tricky to get used to, as it reacts totally different than the factory one.
    Hopefully all of my exhaust mods will help...
    Is that what you are looking for?
    Thank you! But what do you mean by "tricky"? Does it suddenly engages without forewarning or have bad engagement point?
    Engine Builder
    Jul 2011
    Denton, TX
    It's not bad, it's just very different. It also appears that with the flywheel I have to have higher RPMs to engage, it's just a little getting used to.
    I've got the Spec Stage 2+ in mine along with the light flywheel and pressure plate. It's friendly on the street. Much of the tricky-ness is from the rotating mass being lightened so much - the car revs much easier/quicker and the converse is also true when letting the clutch out. Just need to pay a bit more attention or use the e-brake when doing hill starts or running up ramps. The clutch itself is very smooth and engagement feels normal.
    Engine Builder
    Jul 2011
    Denton, TX
    Quote Originally Posted by ckearns View Post
    That's probably a better way to explain it than I could think of. It's alright when I've been driving around a bit, but when I get out for the first time my natural instinct is that I have my old clutch, , takes a second to get back in the rhythm. I don't see it being an issue in a week.
    That's not it but someone else hooked me up.
    It gets irritating in traffic, but the clutch is manageable. I recently sat in Houston traffic with mine, including the 350lb tire trailer, and it's not terrible. The car will bounce pretty hard when backing up slowly with the trailer.
    I see, that all sounded better than the aforementioned CM clutch. Thanks! I will keep this spec unit in mind when the need arises.
    Engine Builder
    Jul 2011
    Denton, TX
    Small update. Finally got my touge run rear spoiler painted and mounted over the weekend , like the subtle addition to my car's side profile:
    Won a set of Bride low max's on fleabay they came in, but haven't had a chance to install them:
    And my Garage Vary front canards finally arrived from Japan:
  11. #31
    Lovely! I think this car is transforming into something gorgeous.
  12. #32
    Chassis Designer lawmaster891's Avatar
    Feb 2012
    North side of Fort Worth
    nice set of brides. I'm saving up for a sparco fighter
  13. #33
    Engine Builder
    Jul 2011
    Denton, TX
    Thanks, slow and steady wins the race.
    Quote Originally Posted by lawmaster891 View Post
    Thanks. The sparcos will look awesome in a Miata.
  1. 96 Montego Blue Miata(running and perfect for a project car)
    By Metsubo in forum dfwMiata.com Classifieds
    Last Post: 04-01-2010, 03:01 PM
  2. New project car over at the inlaws
    By Titus in forum OTM Tech and Chat
    Last Post: 02-18-2009, 12:13 AM
  3. Got a junker Miata? Need a project car?
    By srivendel in forum Miata Tech and Chat
    Last Post: 07-14-2006, 12:01 PM
  4. Treibenschnell project car
    By Kestrel in forum Miata Tech and Chat
    Last Post: 08-31-2004, 11:01 PM
