DTC P0171 Fuel trim system too lean
POSSIBLE
CAUSE
• Misfire
• HO2S (front) deterioration
• HO2S (front) heater malfunction
• Pressure regulator malfunction
• FP malfunction
• Fuel filter clogged or restricted
• Fuel leakage on fuel line from fuel delivery pipe and FP
• Leakage exhaust system
• Purge solenoid valve malfunction
• Purge solenoid hoses improper connection
• Insufficient compression
From this document on obd codes and repair.
Page 71 has the test.
http://www.fastforwardsuperchargers....tall/Codes.pdf
