Does he wear a lot of makeup??
That could cause it.....
My son has a 2010 Mazda 3. The visors are light tan/pale color. They are turning purple. The dealership said we sprayed something on them to turn them but they would replace them under goodwill. This was after fighting and a call to Mazda NA. We have only cleaned them with water as my son does not like the way the detailer spray smells. Any clue why they turned purple?
M3 is always the answer.
Only when your wife makes him wear it to look like an old fat guy (you).
				if it was a stain wouldn't it have also stained the cover for the mirrors?
The smoke from his bong is probably staining them.
Dammit fast fingered Sammm! Was going to say crack pipe.
If he had sprayed them, it wouldnt be on both sides (probably), and should be on the headliner.
Are you sure YOU didn't "spray" something on them, show off??
do you have a black sunshade perchance? My visors discolored after having the sunshade up in this 110 degree heat....
[SIGPIC][/SIGPIC]
No sunshade.
No bong smoke.
Mazda side looks like a chemical reaction based on something I sprayed on them. We only used Allen water to clean them. But Mazda is going to replace them.
