Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
Thread: 1990 NA No Start / I've checked just about everything / Please help
  1. #41
    Quote Originally Posted by NissanFairladyZ32 View Post
    i still dont see what it would help the car idles fine, it just takes awhile to get the RPMS down.
    That I don't know. But yeah, I would definitely jump the pins and set it correctly, then go from there if needed.
  2. #42
    Fixed the problem with the car holding the RPMs up and getting hung up, the car started stalling out and would never run correct till was warm and would still hold the rpms around 2000 and not come back down for 15-20 seconds.
    Turns out there was a vacuum leak in the back of the motor under the CAS, i couldn't find a hose that was suppose to go their, So i capped the vacuum leak off and the car is running better then ever and idling smooth
    99 Miata NB (Daily), 91 Nissan 300ZX Twin Turbo (Toy)
  3. #43
    There is no hose there - it's just a large rubber cap from the factory.
  4. #44
    Feb 2007
    Propwash 16Xray
    That is for the automatic trans modulator, and is on the back of the intake.
    I put an old spring clamp from the coolant line on them.
  5. #45
    I JBWelded a penny to mine the first time I ever pulled the motor. I do regular boost/vacuum tests and it has neve once leaked.
    Can't say I ever looked into what that nipple was for, so thanks for that info.
  6. #46
    Good thing it wasn't needed, capped it and all is good now with his car.
  1. No Start!
    Last Post: 02-21-2011, 08:56 AM
  2. 1990 Miata wont start
    By kylstryl2005 in forum Miata Tech and Chat
    Last Post: 12-07-2007, 04:38 PM
  3. Start 'em when they're young...
    By black roadster in forum OTM Tech and Chat
    Last Post: 02-23-2007, 07:56 AM
  4. First start
    By David Crisford in forum FI Miata Tech & Chat
    Last Post: 10-23-2006, 06:41 AM
