Buy one at Harbor Freight for $17.
does anyone have a timing light i can borrow or come by and check my timing with?
im in mesquite for the week and i work in addison so somewhere around those areas would be great
thank you for answering my question. you are such a helpful person. here, i got you a medal =]]
Drive to my house, time my car.
i'm afraid of the drinkin & shootin
Related question... If I have an OBDII reader, do I still need a timing light to advance timing?
Thanks!
You can set the timing with an OBDII scanner?? Link please.
You can't set timing with OBD2 scanner... It only shows what the ECU *THINKS* it is running at.
I have to check. Haven't hooked it up yet but I'm guessing so. If the ECU supports it this reader should read it. It's a '97.
Exactly. I was just hoping to use it as a readout while adjusting the timing. But you're making me think that method isn't very reliable...
2013 Audi S4
1997 Montego Blue Miata
I suppose I could still use it and simply advance timing until I get knocking. Does the ECU report knock count? Probably not the best idea though...
