Results 1 to 7 of 7
Thread: Mazdaspeed Miata Differential swap into 1999 Miata
    Oil Changer
    Dec 2011
    Garland. Texas
    Default Mazdaspeed Miata Differential swap into 1999 Miata
    I am wanting to put a LS/Torsen differential in my 1999.
    I am told that the Mazdaspeed one will work, however, you also require the axles since they are different from the base Miata?
    What else will I require to make the conversion?
    If I am correct the driveshaft also, I may be thinking of the 1.6 to 1.8 swap though
    I also believe the MS dif has a different gear ratio than a 5spd dif so make sure you know what you are getting into.
    Supporter EricJ's Avatar
    Feb 2011
    Flower Mound, TX
    In my '99, I put a Tochigi Fuji LSD from an '03. Direct swap for the open diff. No changes to axles or drive shaft. I got new oil seals and clips on the axle shafts, < $20. The gearing was the same 4.3.
    Driver BigDmiata's Avatar
    Just west of East (land of Gar)
    MSM has different axles, not sure, but think standard driveshaft. Not sure what final gear you want, but the MSM has 4.1.
    2013 Mazda2 slushbox daily
    1993 Miata (future exocet donor)
    Feb 2011
    Flower Mound, TX
    I forgot, I also replaced the diff bushings. I used the Mazda Comp ones. I don't remember the cost.
    Quote Originally Posted by BigDmiata View Post
    You're right on all points.
  1. WTB 1.8 differential, (rear end swap)
    By ForAllMankind in forum dfwMiata.com Classifieds
    Last Post: 12-11-2010, 06:32 AM
  2. **FS: 1999 Mazda Miata**
    By astig00 in forum dfwMiata.com Classifieds
    Last Post: 05-24-2010, 12:13 PM
  3. 1999 Miata
    By artur1976 in forum dfwMiata.com Classifieds
    Last Post: 10-23-2009, 06:15 PM
  4. 1999-2000 Miata HID kit - $60
    By OZMDD in forum dfwMiata.com Classifieds
    Last Post: 04-20-2009, 10:18 PM
  5. 1999 TURBO Miata with tons of Flying Miata stuff $12,500
    By ATSAaron in forum dfwMiata.com Classifieds
    Last Post: 11-17-2007, 09:52 PM
