Results 1 to 3 of 3
Thread: Chirp during turn
    Aug 2007
    Fort Worth and Houston, TX
    Blog Entries
    7
    Default Chirp during turn
    I've recently noticed a squeak/chirp coming from the rear of the car during slow, tight turns. This may have been happening for a while, but not noticed due to tire noise. (The Yoko YK580s are a lot quieter than the Goddrich Super Sport G-force they replaced.)
    Is this normal? I'm guessing that it means that I need to change my diff fluid.
    Thanks.
    Mike Walsted - Not an expert, just a data point.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
    Could be diff, or rear springs or wornout bushings or wornout exhaust hangers. Lots of possibilities.
    Aug 2007
    Blog Entries
    7
    I changed the fluid, put in Mobil 1 75w90. What came out looked like motor-oil after 5,000 miles. The differential acts more like an open diff now than it did before, and the chirp on turns is gone. If I floor it coming out of a turn, the inside wheel will kick up gravel or whatever if the pavement isn't clean, though.
    I did learn to check to ensure that the washer is on the drain plug before adding the new fluid. Unfortunately, I learned that lesson a bit later than would have been convenient. Thankfully, I had a hand pump so I just pumped the new fluid back into the bottle before putting the washer back on the drain plug, then refilling the differential.
    Hope this helps someone.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
  1. Don't turn right...
    By tailchaser in forum Bull
    Last Post: 03-04-2010, 08:26 PM
  2. WTB NA turn signals
    By creek in forum dfwMiata.com Classifieds
    Last Post: 09-30-2009, 01:27 PM
  3. Turn Signals??
    By POS Racing in forum Bull
    Last Post: 09-22-2009, 07:14 PM
  4. Uh oh... I think I need to turn it down...
    Last Post: 08-25-2007, 02:58 PM
Tags for this Thread
