Fronts
camber -2.5
caster maxed
zero toe
rear
same as fronts for camber and toe
Can probally run even 1/16 or 1/32 toe in on the rear.
I use specs close to this. On paper they sound pretty agressive on tire wear but has worked out pretty well on my car and has not chewed up the tires too bad for the street.
Keep in mind camber is not the main killer on tires it is the combo of both excessive camber and toe. Also factor in the changes from dynamic and static characteristics.
