It has always been at -3.5 to -3.8 with zero toe.
Previous set was Hankook Evo or something. This started about a year ago. I had the same wear with the older tires so I replaced everything in front.
Car is corner balanced for Wookie driver. Alignment is all jacked up when I get out of it. Actually it does not change that much with the stiff springs.
I am at a lost. The only thing left to consider is that the lower ride height has changed the suspension geometry to point that it is now causing this.
Other item is that all my other wheels are 18x10 et25. With this set of wheels front is 18x9.5 et29.
