Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 82
Thread: Clutch Shudder!
    Lots of reported cases where the clutch pack was replaced and the dreaded shudder returned. So I figured I'd just change to a cheater flywheel to eliminate it as a possibility.
    Fixed!
    So I'm making my shopping list:
    • Resurface Replacement Flywheel
    • Clutch Kit
    • Rear Main Seal on the Motor
    • Front main Seal on the Transmission
    • Shift Boots
    • Little bastard cooling hose for the oil cooler
    Anything else I am missing?
    • Clutch Kit
    • Shift Boots
    Throw out bearing and Transmission tail shaft seal. Maybe go ahead and change the trans fluid while you are at it since you will most likely spill some on the floor anyway. Maybe the bushing that goes on the end of the shifter since I just had to replace mine recently. How about a braided slave cylinder hose? I have a used one I'll sell you cheap. Probably also a good time to check the motor mounts since the drivers is normally a PITA to access with the exhaust in place.
    Change tranny fluid while you're there?
    What tranny fluid does mr. brg recommend for a 6 Speed??
    "The fluid excreted from a transvestite during sex or transaction.
    Some examples : I was drunk enough not to really care that she turned out to be a dude, I just wasn't ready for all the tranny fluid."
    Mazda Value Clutch Kit p/n BP07-16-490-MV (1994-2001)?? 2001! Why not 2002.......
    http://www.buymazdaparts.com/parts.c...id=115&catid=7
    *Update found another website showing it will work 1994-2005!
    http://parts.arlingtonmazda.com/prod...0%252dMV).html
    Parrtial parts list :
    VPM,CLUTCH KIT Part No : BP07-16-490 -MV
    INSULATOR Part No : NA01-64-481B
    BOOT,DUST Part No : M513-17-480A
    SEAL,OIL C/SHAFTPart No : BP05-11-312 (have one)
    Not sure if it is the same for NB 6MT, but the Motorcraft Synthetic trans fluid has been terrific in the NC, much smoother shifts than oem. Pretty reasonable at any Ford stealership.
    +1 .... I switched to it 2-3 weeks ago. Big improvement!
    Here is what we suggest when doing a clutch.
    Clutch and pressure plate
    Throw-out bearing
    Pilot bearing
    Rear main seal
    Front trans seal
    Front trans gasket
    Tail shaft seal
    Motor mounts (If your's are original they're probably torn. Since you are removing the header anyways, the motor mounts are a few more steps)
    Gear oil (2 qts)
    Small and large shift boots
    Optional
    Lightened fly wheel
    Diff Oil (1 qt)
  11. #31
    Thanks black roadster!
  12. #32
    Front trans seal - OIL SEAL (H501-17-103)
    Front trans gasket
    Tail shaft seal - OIL SEAL (M507-17-335A)
    Motor mounts (If your's are original they're probably torn. Since you are removing the header anyways, the motor mounts are a few more steps) RUBBER,ENGINE MT. (NC10-39-040)
    OK so I figured out all the part numbers except for these listed above.
  13. #33
    Is this the front trans gasket?? - GASKET (FE50-16-225A)
  14. #34
    Current shopping list
    Front trans gasket - ???
    Motor mounts - RUBBER,ENGINE MT. (NC10-39-040)
  15. #35
    ^I might have some new 'spare' parts from when we did my '95. I'll check my parts box when I get home tonite.
  16. #36
    All the parts look good if it's a 5-speed. The front trans gasket is for 5-spd only and is FE50-16-225A
    If you have a 6-spd, forget the front trans gasket and replace the front trans seal for Y601-17-131
    Why not go with the mazdaspeed motor mounts? I can bring a pair to Propwash if you'd like.
  17. #37
    Why?? This car is a daily driver not a track car.
    Thanks Again for the help!
  18. #38
    Car driven by teenager = track car
  19. #39
    I guess I just don't see the advantage.
    Why put the competition mounts on it? More vibration?? Impress the JDM crowd?? Why???
    Actually I just asked the kid and she likes it the way it is so stock mounts is what I'll get. I can always switch them later.
  20. #40
    Honestly it's your call and yes you will feel a little more vibration with the MS mounts, but they will also last longer.
  1. clutch gone
    By doc in forum Miata Tech and Chat
    Last Post: 09-27-2008, 10:20 AM
  2. Clutch gone???
    By cArAzzIE in forum Miata Tech and Chat
    Last Post: 03-19-2008, 08:43 AM
  3. Clutch engages early OR ...early clutch release point
    By joe.MIATA in forum Miata Tech and Chat
    Last Post: 02-11-2007, 02:15 PM
  4. HELP!!! Clutch is going out.
    By brock in forum Miata Tech and Chat
    Last Post: 03-15-2005, 02:12 PM
  5. I need a clutch!
    By sammm in forum Miata Tech and Chat
    Last Post: 06-28-2004, 10:11 PM
