Results 1 to 18 of 18
Thread: Problem turning on
    Default Problem turning on
    I already changed to a brand new starter but i'm having a problem constantly being able to turn the car on. I put the key in, and someone it works, sometime it doesn't..It kind of seems like it has a mind of its own, what do y'all think could be the problem?
    silver 91 miata - no mas
    gold 91 miata w/ hardtop - no mas
    99 emerald green mica miata - just found!
    Ignition switch.
    Is there a clutch pedal switch on Miatas? On a few other manual cars I've had, there was a switch on the clutch pedal that would let the ECU know the pedal was depressed. If the pedal was not pressed down, it wouldn't turn over the engine, in case the trans was in gear.
    '06 RSX Type-S NBP
    Don't we need to depress the clutch pedal to get our Miatas to start?.......I believe the answer is yes and yes.
    Jul 2004
    Collinsville, TX
    When you say it won't turn on... do you mean you turn the switch and you get nothing? No lights on the dash? If that is the case then, yeah, ignition switch... if the lights on the dash come on, but it won't turn over, then next I'd look at the clutch switch.
    Dave
    "Opinions are like ..."
    yeah it turned on fine this morning, its weird cuz when it doesnt want to turn on, dash lights work, ac works, even the headlights
    and yes i do have to hold down the clutch to turn on the car
    it did it again during lunch time and took a video, after recording it, it turned on, but at least yall get to hear it.
    *sorry for recording upside down though
    http://s1185.photobucket.com/albums/...727_124130.mp4
    You had the battery checked out?
    Hard to tell much from the upside down fuzzy video but it sounds like a weak battery.
    Also possibly an ignition switch.
    it must be the ignition switch, cuz the battery is only a month old
    Quote Originally Posted by ozzie84 View Post
    That doesn't mean the battery isn't bad. I've seen 3 in the last week with Walmart batteries do this, battery tested bad, replaced under warranty.
    '01 Miata. Silver/Red Stripes. HDHCDD
    '13 Mazda2. Spirited Green.
    Have you tried it with a new key? Or with the key wrapped in foil?
    Foil? I don't think its the battery, but I can remove it tomorrow and tell auto zone to check it
    Have the battery tested. Re-check the battery terminal clamps for tightness and corrosion. Check that your engine block grounds are tight and corrosion-free. Check that the power and signal wires on the starter are secure and corrosion-free.
    The video you posted sounds like something is clicking under the hood, so your first tests should be for low current and a bad starter motor. You stated that the starter motor is new, so worry about the electric current first.
    1994 R-package - gone, but not forgotten.
    1966 Toyota Land Cruiser FJ40. Restification in progress. or should I say De-RUSTification in progress?
    1984 Honda VF1100S. V4 Fury!
    I just finished cleaning the ignition switch, like recommended on another forum, it was quite gunky inside, so I'll try to run the car all day and see if I don't have the problem again
    Ignition switch.
    Quote Originally Posted by Dave04 View Post
    Yea for the other Forum! No one here even mentioned the ignitions switch.
    ran all day yesterday and so far today....
    Aug 2007
    Fort Worth and Houston, TX
    Blog Entries
    7
    My Miata will have an issue with starting if the ground connection underneath the car isn't clean and tight.
    Mike Walsted - Not an expert, just a data point.
    1999 Miata
    2003 MIata
    1999 Miata
    2001 Kia Rio
    The foil method will gain you 5-10 hp.
  1. window problem, door problem, and query about the front end
    By Rufus in forum Miata Tech and Chat
    Last Post: 08-01-2010, 12:02 AM
  2. 94 turning over but not starting
    By Mathews2004 in forum Miata Tech and Chat
    Last Post: 06-17-2009, 10:24 AM
  3. What seems to be the problem?
    By Titus in forum Bull
    Last Post: 12-29-2006, 09:15 PM
  4. Wii have a problem
    By sammm in forum Bull
    Last Post: 11-30-2006, 10:03 AM
  5. Turning Question
    By Billy Blaze in forum Autocross Tech & Technique
    Last Post: 05-03-2005, 10:40 PM
